Want to change from 22 in radiator to a 26 in radiator
74DartSwinger360
The Brat Pack
Valrico, Florida
I have a 1973 Duster I want to put the max cooling package on. Want the bigger radiator to eventually run a big block.
Need help on where to cut and do it right.
Thanks
Are you sure cutting is req'd ? I think your 22 inch radiator may have filler brackets on both sides so it mounts in the 26 inch opening.
your not reading what he said , your 22" rad is mounted to a pair of filler panels , when you remove the 22 you also remove the 2 flat panels it is bolted too and bolt the 26 in their place simple .
How about that. I never would have guessed the factory used 2 different parts there in 73 models. Learn something every day.
