[WANTED] Wanted 66 abody 273 power steering pump
Bikerchris
Canada
Rating - 0%
0   0   0
Looking for power steering pump and brackets for a 1966 dodge dart or Plymouth valiant must be for a 273 engine I’m located in simcoe Canada
I’ve got an excellent one from a running 273. PM me if interested.
Jake
You may need the add on pulley at crank too. That bolt pattern wasn't symmetrical in early models. If only pulley available is from later model you'll need to alter/oblong one bolt hole.
Check clearance between p/s belt and lower radiator hose before you crank it up.
Good luck
