[WANTED] Wanted 8 3/4 30 Spline Axle to use for alignment
sgaugian
Olney, Maryland
Looking for only spline section of a 8 3/4 axle to use for alignment of sure-grip segment. If anyone has an old junk axle and would cutoff 6"or so including the spline, I would be interested in buying. PM please.
You can also use Dana 44 axles, they are the same spline. Just in case you have or can source then easier. If you were closer I would give you a pair. Also like RRR mentioned above, you really need two of them.
