Wanted manual steering box
Dont need a column? I have a matched column,box and pitman arm with a new ign key and switch. Im thinking of going to rack and pinion so might sell.
thanks guys I already got one
its not for a mopar im using if for a cowl steering setup in a model a hot rod
thanks for all the replys and messages
Now that cbellamore is taken care of, does anyone have a trick for getting the coupler off the splined shaft? Even with the roll pin out, it doesn't want to come off.
Soak it in WD40 and tap on it with a hammer/punch/chisel/picklefork to drive it off the splines.
