Wanted - Trans X Member, 14x6 Chrome Reverse
tw7912
Burleson, TX
Need a transmission (904) rear crossmember with or without mount for '66 A body Cuda. Also looking for 14x6 SBP (4") chrome reverse rims and aluminum 273/318 small port 4 bbl manifold (offy/weiand?). Located in DFW Texas area (76040).
Is there a cross member in the car at all? MaMopar didn't make different cross members for auto or manual.
Grump, yes there is a crossmember, some id--- cutoff/beat down the right side to allow dual exhaust clearance. I'm going back to the original hi-po 273 exhaust and fixing problems like that. You're correct, no difference between manual/auto crossmembers, not sure if they're the same between years (66-67, etc). Cheers, Tom
. . . not sure if they're the same between years (66-67, etc). Cheers, Tom
63 thru 66 cross members are the same, 67 thru at least 72 and I'm not sure about the 73-76 ones. Too bad you didn't need a 67-72, I've got one you can have already boxed and ready to go.
Dartman, that's what I suspected. Thanks for the info and offer. You're obviously a member of the 'good guys' club also.
