64dart170
Is it a bad idea to clean and reuse the old gaskets? I like the cost savings even if I have to use a little elbow grease but will it still seal? I need to find a new front and rear soon or go the re-use route.
It's a great idea, especially now with the shortage.
2 words;
MINERAL SPIRITS (see pics)
It's a real job and a real mess, but worth it now.
I even have a pre-cleaned old 4 door winshield gasket hanging in the garage for the next time!!
The gasket after drenching with wet rag and rubbing it forever will resemble wrinklie bacon. mmmmmmmbaconmmmmm
After 24 hour dry time after cleaning it will go back to it's normal shape.
So everyone here at FABO,
PLEASE stop cutting your old gaskets for a while, K?:glasses2:
Better yet, pay the $100.00 bucks for a remove and replace labor only at your local glass shop. They will show up, tell them to save the gasket for reuse. They remove and leave. You clean and prep glass, gasket and car body work. Then call them back for install, all at your garage. They use their own sealer ($15.00 a tube and make sure they use enough all the way around!) They are responsible for breakage during removal and install and better yet they are responsible if it leaks after install. It's the best $100 (per glass) you'll ever spend!
Invest in rubber gloves B4 job!!:glasses2:
I also used the mineral spirits to remove the glue on the roof under the old vinyl too!
