Water pump bypass....
RustyRatRod
Caput villa stultus
Georgia
My 331 Hemi is MUCH like a small block. They are almost identical sizes block wise. They even use a small block timing chain set. I have the Hot Heads timing cover that allows the use of a small block Chevy water pump. Mega easy to find versus the factory Hemi water pump AND it hacks close to 50 pounds off the front of the engine.
Anyway, for a few reasons, I want to eliminate the water pump bypass. I have everything to run it, but it looks stupid and it would look much cleaner without it. Anyone see a reason why I cannot delete it?
I had planned on drilling some extra holes in it.
