360
I have a 1978 360 bored .030, Edelbrock aluminum heads,Northern aluminum radiator with dual 10" fans mounted in a shroud, Milodon 180* thermostat, water wetter added to the coolant, 8 blade M/P water pump. My inlet temperature is higher (195*) than the outlet temperature (176*). This should be just the opposite. Running an AutoMeter electric gauge and the engine runs at 205*-208* at idle, crusing or running down the highway. I checked the temperature with a infared heat gun. The temperature sender in the intake maifold read the same as the gauge. Any ideas?
