Mounted but never used. Fits non A/C cars only. Gasket incl.
Pump is in Albuquerque, NM.
Note- if you are going to try and look up the part number for proper fit you are wasting your time. Most sites will tell you that this pump is for A/C cars and I assure you, it will not fit with your factory air. What it DOES fit is any of the older small blocks that came with a cast iron pump that exits on the drivers side.
