Water temp sensor
dartlove
northern Ca
Anybody running remote water pump with gear drive on big block? If so where did you put water temp sensor?
That was what I was thinking, but have not been able to find -12AN x 1/8 npt type fitting. Any ideas on finding a couple.
Drill and tap the spacers in front of the motor plate. Not enough room there,thicker spacers.
There are no pipe plugs in the heads. I bought a couple more chunks of aluminum to Mill new spacers so I can tap them
