Fast01
Ok, I'm changing my motor over from throttle body injection to multi point. There are no injection manifolds available for the "B" block except the Indy single plane, but I understand my Victor 383 is better out of the box. This leaves me to convert what I have on hand. I'm looking for some input/opinions on what direction to go.
The motor is 517" (4.402x4.250) with a Comp solid roller (12-705-9), 12.49:1 and Trick Flow 240's. Also has a direct port nitrous system. I was wanting to convert a Weiand tunnel ram I have sitting around, but putting together the cost to do so, I'm not sure it's worth it. For less than the cost of the mods required, I can get a new Indy tunnel ram that is already cast with injector pads, making the conversion something i can do myself. From a performance standpoint, which manifold would you guys use? I've seen good things about the Hi-Ram, but can't find too much on the Indy. Thanks for your replies!
