the car has sparco milano 2 seats with just the cheetah shifter and the plastic cheetah console cover, a 4pt roll bar, rmd dash, 4 pt harnesses, battery moved to trunk on passenger side, and small amp for interior wise.
engine has alum heads, tti headers, x pipe with hooker aerochambers, mini starter, air gap intake, holley 4160 carb, magnum air filter and valve covers, stock water pump, summit damper, clutch fan, alum radiator, alum trans cooler, 727 trans, no heater box or a/c.
stock suspension up front minus the wilwood disc brakes and light weight master with 26x6.4x15 bfg silvertown tires, slant 6 torsion bars. the rear is a 8 3/4 with 3.91 sure grip, ss leafs, 29x12.5x15 m/t sportsman tires, cragar wheels, stock fuel tank, holley gerotor pump, ss braided lines with an fittings, also 11" drums out back.
