hocus
New Member
so i got a 1975 dart swinger and i just replaced the 2nd,6th,and 8th fuses and now when i put it in gear a buzz comes any suggestions on what it is?
i will thank youId pull em one by one and see if it stops after each, then reference the wire diagram and see if that gives you a clue... just a jumping off point...
thanks guys i have a friend coming over in the morning to help me pinpoint it and fix it you been a great helpBy 1975 I'm sure you got buzzers in there that someone disconnected. And that's another thing, and that many years somebody's done something to the wiring generally.
Had that with mine, easiest is to pull the pass kick panel they are there just unhook it and it is disconnected.First thing I would try is unhook the seat belt warning wires under the front seats.
