Tmac85
Take a look at these pics. Looks to me like a cracked bell housing. Hacked dust cover. And wrong pan gasket??
it won't (or shouldn't ) leak - it's new - everything will be there - it's new - you can do it yourself - it's new - you can order it however you want it - - and - it's new!
true enough..Problem with new is that it doesn't always mean right, and new isn't necessarily "new" anyway.
It's probably been 30 years since I saw a "new" 904" instead of rebuilt.
I would much sooner have it done local so it wouldn't be a huge pain if it needed to go back for any reason. (which seems really common these days)
AH HELL, maybe I should just come over and help you drop a 42RH overdrive in there.
I paid $125 for mine with the HD lockup converter out of the U Pull It yard, and went through it adding a stage 2 Transgo shift kit in the process for right around $350 total.![]()
ive done r&r for a really good tranny guy, 1800 was the cheapest he would do one.and he gaurantee his trans for a full year unlimited milageSo I figured since I was going to pull it anyway for the front pump seal that I might as well rebuild it. Bought a TCI super pro rebuild kit. No lift, was just going to use jack and stands. Just got a quote for 1000 bucks to rebuild the tranny and that includes removal/install and towing. Does that seem fair? And also should I go ahead and replace torque converter as well?
