oliverwade2
New Member
I have been told by quite a few folks who have worked on A bodies that after I put the upper ball joint in the upper control arm, that I should put a spot weld in it to keep it in place.
That sounds a bit radical to me...maybe blue or red loctite instead ?
I also notice (and I asked this question where I bought the pieces) that the ball joint leaves quite a space above the knuckle when inserted. I was told that the seal which fills with grease takes up this difference and I should just torque the but to what ever the specification is.
Thoughts ?
Thanks
ian.
I noticed my ball joint was a bit loose when I pressed it in so I put four stitch welds around it and it has held up for 50k?? I am a tig welder and fabricator for a living and if this is done right there is nothing wrong with it. You can even grind out the old welds if you need to replace again. The only reason this could fail is if the welder did not know what he was doing. I welded on top fuel chassis for Murf Mckinney for years and you would be surprised how little weld it takes, done right that is. To keep a car together. No worries.
