[WANTED] well working radiator for 1966 Cuda needed ASAP! For automatic 225 slant six
'CudaChick
Active Member
Chico, CA
Rating - 0%
0   0   0
looking to buy a 1966 barracuda radiator, perhaps would fit a 1964 or 65 Cuda radiator, as well as other cars? as well as gas sending unit for inside tank, rear light lenses (and bulbs?) anything to make it have good gas mileage, Petronix, shocks, Ect.
Thanks!
I have a rad from a 66 belvedere 225 good shape just one of the brackets need to be soldered on top.
Instead of using a 19 in slant radiator, you could do what I'm doing - I took an early A 22 inch V8 radiator, had it recored to a 3 core (optional in this case), and had the radiator guy remove the old V8 hose nipples and add the slant ones to the radiator where they would have been placed if a slant 22 inch radiator had been offered for the early A. Don't care to do that, then the interchange is a 63-66 slant radiator. You might be able to swap a 67-later by redrilling the mounting holes in the side panels and/or core support.
I will look and see if I have a good gas sending unit.
