Went to track last night with duster
71dustar
Fountain Hills, Az
Finally got around to taking the duster to the track after finishing it back in the summer of 2010. I didn't have slicks since i wanted to get a rough baseline of what the car could do. I was running about 10psi in the m/T sportsman tires and was getting:
2.2 60ft
5.8 330ft
9 1/8 mile
I couldn't run full out for 1/4 mile since my cutoff switch doesn't have alternator wired to it so technically doesn't work and lug nuts aren't safe so i was practicing launching.
Car has 3.91 gears, 408 stroker motor with 750cfm holley, 3500 stall, 727 rev man body, and other things (look at my info to see it all).
One thing that I had a problem with is when i would burn out in second gear (since first gear doesn't have engine breaking) and i would stop suddenly the would die. I think its due to I have jet extensions on the secondaries but if you guys think its something else please let me know.
In all it was a fun night. Last pass of the night I ran a 13.4 at 110mph spinning off the line hard. Next time around once i fix a few things I'll be going with slicks.
which track did you go to?
I should have my Dart done in a couple weeks, we should meet up sometime at the track (speedworld).
I have never run mine, but it usually ran 11.20 @ 117 in Vegas from the guy I bought it from.
I'm hoping to get mid 10's after I'm done with it.
I went to firebird since it was close. I usually got to speed world because the track is better prepped, less crowd, and i enjoy the environment out there more. I'm hoping once im done tuning and getting slicks i'll be in the 11's
