Were 70-up A-Body back seats the same? Seat ID help needed
66340SEDAN
FABO Member #3649
Minnesota
Are 1970-up backseats the same? I know the Duster and Dart Sports that had gold down rear seat was different...but were the seats frames themselves the same from a Dart/Valiant same as a Duster? I have a seat, not sure what’s it’s exactly from, each section has an aluminum tag with a MoPar part number, here are some pictures, thanks!
Stitching on covers are 73 -up...really dont know if frames are same as 70-72..tabs might require a sheet screw instead of fold tab
That is the same as a 72 up. The way you can tell is by the cut outs in the corner of the bottom for seatbelts. Also the seat back bolts in verses earlier seat has the fold over tabs in the corner. The Duster or Sport style are also different seats then Swinger /Scamp The seats you have look to be swinger but not sure. They are different lengths and heights but can be stuffed in.
And I may add that that's a 2 door seat, the 4 doors were rounded on the bottom section to allow people easier access to the rear.
