I posted yesterday about the mess I had in the engine bay with all the wiring problems. I spent all day trying to figure out what was going on with this. I can tell you one thing for sure. This car did not run to where I found it. Someone had 3 extra harnesses on this engine. I would have some wires running out of the bulkhead going nowhere. And some wires was hooked to the alt., coil, and some other things and was not even ran to the bulkhead. So I took your guys advice. I got my schematic out, had to use 2 different ones, and I started with one harness and ran the wires down to where it should have went and hooked em in. I had to replace one of the harnesses. It looked like at one point thie engine bay had a bad short in it and I think that is where someone who knew nothing became a mechanic and decided to drop out of school in the middle of the class. anyway , it is wired according to the diagram. Dont know yet if it is right but it is wired. Thanks for all you guys help. I may need more help later when we get deeper into the process. My son just found out last night when he put water in the radiator that bonnie & clyde must have been close to it. Looked like a sprinkler. He will need to get this redone. this pic looks a little better but I have to finish up the final routing of the wires. I had to stop working because I have a business meeting at church tonight. Thanks again for the help guys. Bill
