what are the best spark plugs to run on a 1975 360 motor
need more information than that. ideally...
is it bone stock? 4bbl or 2bbl? any mods? what's it in? what do you use it for or how do you drive it?
a stock 2bbl in a motor home is gonna want a different plug than a hopped up 4bbl in a valiant, ya dig?
Hi stock 4 bbbl
Hi stock 4 bbbl
any of these will be fine. dealer's choice.
If you use NGK, try to use the non-resistor type. BP4ES or BP5ES. ‘BPR’ means resistor plug.
As long as you use a 4 heat range if you are using NGK [ a good idea ]. From testing I have seen, the res plugs & resistance of the leads does not hurt power in the average hi-po engine.
In the test below, a non-res spark plug got the lowest hp....& the highest hp was not with the lowest resistance leads! Buy a good brand of spiral would leads...& worry not.
Spiral/heli leads are an inductor [ a coil ]; because the wire is wound around a ferrite core. So, compared to capacitance & resistance in the mix which you have with solid or carbon leads...you now have inductance also; this might explain the results below.
