Duster Fan
I was thinking about using these: http://m.summitracing.com/parts/TCI-821500 to mount my fan and cooler to my radiator.
probably cooling efficiency considering both are just like heat dispersing coils and you have one soakin one with heat and vice versaNot the best way to go about it. I have never had any luck with the trans cooler zip tied to the radiator, did not do much for cooling the trans. Keep in mind that this was on a tight finned 3 row cored radiator. But then again damn near every vehicle that I have ever owned as a toy had cooling issues.....Most of the newer vehicles I have ever looked at the cooler is a few inches from the radiator, must be a reason the factory does them that way....
It's better to use a Rad with built in Trans. cooler. But if you already have the cooler......
Sounds like a good option. Would you put the cooler before or after the Radiator?use them both. the rad cooler and one that mounts out front.
