What are these bolts called? Steering column under the hood.
Bronze Barracuda
Vancouver
Good morning.
Can some tell me what these bolts are called they are on steering column under the hood?
Thank you
Back when I worked at the Warren Truck Assembly Plant building Dodge trucks we called that the rag joint and those were the rag joint bolts. I can't really tell from the picture but that does look like one of the old Dodge Trucks.
Yeah 81 Ramcharger. I couldn't remember if I removed similar bolts when I took my Barracuda apart. Were they used universally on dodges back then?
What are you working on that uses a rag joint? That's a GM thing.
Back then Dodge Ramchargers, Plymouth Traildusters, and all size Dodge Trucks were all built on the same lines and yes that part was called a rag joint. All of them used the same part along with the same bolts.
I posted the same question on Ramcharger Central. I was thinking I had somehow forgotten this when I was disassembling the Barracuda. But I guess it was only a truck thing.
Oh, and Junkyard hero. Great idea, I'll incorporate that into my next set of wrenches! :lol:
The red areas sandwich the rag joint between the steering column part and the steering gear part.
The green area is an extension of two of the bolt that makes a fail safe if the rag comes apart.
According to rockauto... 81 ramcharger uses a slip joint like the cars do. Might not be stock?
70 Ford Mustang and F250 pickup
Basic same idea
Chrysler used Saginaw columns through the late 70's & into the 80's In passenger cars they were used if the car was optioned with tilt.... In the trucks it was sort of random... All the tilts but some of the standard columns to...
Everything in and on the trucks was kind of random, I remember when we would run out of certain things we would use whatever we had to keep that line running. Sometimes it was an upgrade and sometimes it was not. I was at the truck plant for 35 years and I spent 1 year at Viper and prowler which was pretty cool because every day I played with toys, they were someone else's toys but I got to play with them first.
Hmm interesting. My RC does have tilt.
I have a 85 1/2 ton with tilt and it uses the same joint.
Don't know abut A body, but B body cars got that same joint/coupling starting in 1974.
You can get that part in the "Help" section at most auto stores. Same as ford.
