what are these called?
jdsduster
indiana
the little plastic square inserts that go in the seat hinge,so you can screw the hinge cover in to? two of mine are gone and i cant put the cover on.where the hell will i ever get them???
For the description, try nut. More specifically; Nut, front seat hinge cover, att screw, 6029 501. That's as close as I could come using the parts manual. The parts manual has a bunch of seat illustrations, some of which show a cover, but there is no illustrations of it. Hope this helps.
I have quite a few different kinds of good used originals but need to know what year, bench or buckets as was mentioned. Send me a message if you don't find them at az
i will take a wild guess here since you don't have a picture, but i think the inserts you're talking about are pretty common. they should be like 1/4 inch, 3/8 inch square. you can get them at home depot electric department or at an auto parts store where the interior fasteners are.
take a picture of the area where these go - after seeing the pics, the "experts" here on FABO should be able to point you in the right direction.
