ratvon
Having trouble making this set up work in my 68 barracuda I'm beginning to think the linkage rods are wrong. The shifter arm is stamped 6353
The Transmissions is out of the car for now but getting ready to put it in with the engine never ran the transmission shifter or linkage before . When I use the 3/16 alignment pin nothing seems to reach or fit correctlyIs the transmission in the car or out of the car? Have you ran the transmission before? Have you ran the lever before? And probably more questions if you want help...
i.e. - more information please...
Yes it's a Hurst I don't know what it came out of a reliable friend sold me the shifter and linkage and I just went on his word... do all the adjustable ends go to the shifter?Is the shifter a Hurst unit?
And still, what levers do you have? It makes a big difference.
The shifter mounting pad could be wrong for your application. Bought a used 4 speed set up that was pieced together, was not sure what it came out of, after a long time trying to figure out why linkage did not work, checked a buddy's a body and found shifter plate was way different. they must of used a different shifter previously.
Now there is some good information thank you very much
