What bulbs and fuses for '65 Barracuda?
dibbons
La Paz, B.C.S., Mexico
Anyone have a complete list of bulbs and fuses for a 1965 A body? The factory service manual does not seem to list this info. My fuse block lettering is so worn I no longer can read what size fuses to use. Not only that, some lamp sockets are empty and I have no old lamps for reference (i.e. the floor shift console bulb, under dash courtesy lamp, back up lamps, etc.) Thank you.
For 65-66 model years across the Plymouth line...here we go:
ash receiver (ash tray) #57
auto pilot 57
back up lights 1073
dome lights 1004
clock 57
door and or pockets 90
emergency flashers 57
fender mount turn signals 330
gear selector indicator 1445
gear selector with console 57
glove compartment 1891
hand brake indicator 57
heater/AC control 1893
high beam 158
instrument cluster illumination 158
ignition switch 158
license light 67
map light 90
oil pressure 158
panel and or ridge light (?) 90
park and turn signal 1034A (amber)
radio 1893
sealed beam single 7" 6012
tachometer with console 57
tail stop and turn 1034
trunk/under hood light 1004
turn signal indicator 158
Fury has a few different specs on 3 bulbs.
Check out Grainger.com for pics and specs on their GE lighting
For the fuses, looks like they are (looking at block with fuses on bottom from left to right:
<<instrument/LPT (2A*)<>tail/stop/dome (20A)<>cigar lighter (20A) <> ACC 20A RR AC 20 (20A) <>HEAT A/C (20A)<>RADIO (5*)>>
* Radio and instrument are not called out by amperage, had to look in FSM. they are RADIO 5A, instrument lights 2A (a-body) 3A (Belv-Sat) and 4A (Fury)
numbers are bulb style.
from 65-66 FSM pg. 8-100
Anyone know if the '65 Formula S factory in-dash tachometer uses the same mini-bulb (#57) as listed above for a "tachometer with console"? Thank you.
