Or should I sell all 3 carbs and get a street demon? What is so great about Demon carbs? I have heard they are good carbs but why?
The appeal behind the Street Demon is nearly the same as a Carter ThermoQuad. They have the same design principals, set up for street use performance. The design principal behind a Carter Thermo Quad, Street Demon are based on keeping fuel temp regulated at a lower temp with the plastic body, to prevent boiling/ vapor locking, while providing a lot of atomization from using multiple boosters in the primaries, coupled high velocity throughout the entire range of the primay openning, to help atomization.
The more atomization you get out of a carburetor, the more efficiently it will burn.
Holley makes these, there are some videos and other info about them on their website -
http://www.demoncarbs.com
You could do the same thing with a Carter Thermo-Quad, but sometimes finding jets to tune your carburetor for them, as well as finding one that isn't warped can be tricky. You can get new bodies for them for around $100 if needed, to get proper sealing.
The reason a lot of people stray away from them or love them is because they have a sophisticated idle and cruise circuit, meaning different throttle positions feed the carburetor through different metering systems, so if the throttle position is off from idle, it hinders tuning the cruise and give false fuel metering.
If a ThermoQuad is tuned properly, they run great for street use. They are not the greatest race carb, in my opinion, because of how much the running conditions change in them between idle, cruise and secondary systems. You won't get very consistant runs in rounds, if you are drag racing one, but for street use, they do the right thing. You will need a spread bore intake manifold, preferably a dual plane, in order to run one of them, because they are a spread bore carburetor.
Some of the reasons I went with the Street Demon is because parts are new, I don't have to go through it myself and chase problems out of the one I have (including replacing it's body on the particular one I have) and they fit on a square bore intake.
I think the principal behind a square bore gives more even distribution within the manifold, than a spread bore. The Demon also has a really nice idle feature that helps stabilize it, with an air bleed at the base of the carb, right in front of the primary throttle plates that helps move the air that comes in at the front openning of the throttle plate, back toward the center of the carb.
I also like what they did with the goggle valve secondary, because it helps equalize a dual plane manifold up at higher RPM/throttle, similar to an open passage in a dual plane divider, to get a bit more balancing and power out of the top end of the RPM range. It also helps gain more CFM in a smaller bore pattern, which again, helps fuel mapping, over a spread bore design.
There are sources that do a great job with rebuilding Carter Thermo Quad carbs and do a good baseline tune, but they are about the same price as a Demon. You could learn, yourself, but it does take extensive jetting/ metering, idle mixture, timing and parts that you may not have access to right away.
The best way to go about rebuilding a Thermo Quad is to accumulate all of the parts that you will need for your altitude and tune it. Anything you can use, like a tach, vacuum gauge, timing light, 02 sensors and reader to give you a visualization of how it is running at idle, cruising rpms and wide open throttle are going to give you the best results. That is a good way to gain a baseline, then as stated above, do some passes with it to tune it even further, to get an idea of what it is doing under different acceleration loads.
Basically, by going with the Demon, I just decided to skip the rebuilding aspect of doing my Thermo Quad and started at tuning. They baseline tune these carbs at sea level and are adjusted pretty close to what you will see, with the exception of some minor parts changing and adjustments within small incriments to perfect it on your engine.
If you want high RPM performance, go with a Holley. If you want economy and something more friendly on fuel, go with a Carter Thermo Quad or Street Demon.
