magnumdust
So i'm at a complete loss as to what my ignition system is doing.
The car is rewired via a ron francis kit and the only alteration from their instructions is that instead of the "column/ignition" post, i'm using one of the switched accessory prongs. Because the kit is intended for chevy/ididit type steering columns and can't fit 3 prongs on that post. I wouldn't think this should be an issue, but tomorrow's last straw before i concede to sending to a shop is to splice the column wires and put the ignition prong there.
While running if you try to use a timing light, you'll see that there is an intermittent miss. Instead of the constant strobe, it will be flashing and then a half second-1 second of nothing, then it will flash like normal and repeat the cycle.
1st ignition setup:
4-pin hei with a pro-comp e-coil mounted to a piece of aluminum for a heat sink(thickest sheet i could find at ace hardware). Wiring was from the acc. post to a 4 pin relay, same relay also turns on my efi system.
It runs and sounds okay cold, then goes to hell as soon as the car warms up a little(say 2-3min in the driveway). I tried a few modifications, redid the hei mount, but the problem persisted.
Then i got frustrated and figured something wasnt working for me w/ the hei. So i purchased the second ignition system. A nice pertronix II billet distributor.
The car ran *slightly* better, but the problem persisted yet again. I tried buying another coil to make sure it wasnt the pro-comp coil. Still the problem persisted. I eliminated the relay from the wiring and still the problem persists. :banghead:
1st ignition setup:
