What Champion Plug ru Using in you 340?
Well my block is a 73 running J heads with TRW 12:1 pistons. Compression is a little high on pump gas as it’s not stock so I want to go with one heat range from stock. Which I believe to be rn9yc or n9y not sure of the difference.
When you go to Champions ******* web site they use different part numbers like 405 for some dam reason.
Then you go to technical help they have no heat range charts or anything but they do show you how to change oil!
Dam retards over there or maybe someone can prove me wrong and show that Im the retard.
With all that compression, run 9's beat on it and read the plugs. They will probably be too cold. That should tell you if they are too cold or not. Many plug reading threads here on the site.
I ran the RN9YC’s in my 340 when I had cast iron heads as my local speed shop told me that they were the next step down from the 12’s on the heat range.
For what it’s worth, a few years back I had a few champion plugs lose the insulator around the electrode so I have switched over to NGK plugs and have not had any issues since.
Well back in 71 that epa mandate changed compression across the board. My 71 454 dropped to 8:1!
I wonder what the C means on the Champion plugs. Another thread someone like Yellowrose or someone said it was a “better quality “ plug wtf?
Lower # = lower heat range with Champion. R= resistor, C= copper.
340's started out with N9Y and used N12Y in 1973. Not sure about 1972 - may have been a transition year, like with forged to cast cranks.
Other 1970+ were usually-
426 Hemi= N10Y
/6=N14Y
318=N13Y
360=N12Y & N13Y
I had some N7Y and N63Y plugs long ago, which were considered cold race plugs. There was some footnote about N63Y and similar #plugs as far as heat range goes but I don't recall the details. See bottom of chart.
There are some plug crossover charts out there. Just gotta find the ones with the plugs & # code you're looking at.
426 Hemi= N10Y
/6=N14Y
318=N13Y
360=N12Y & N13Y
Wouldn’t you need more/hotter spark in a lower compression engine?
R = resistor
N = 3/4" reach
7/9/11/14 = heat range
c = copper center electrode
Personally I haven't run Chumpions in over 40 years... they suck..
NGK or ND...
C= copper
What Champion Plug ru Using in you 340?​
none, i only use ngk. :thumbsup:
the 'c' is for crap :rofl:
:rofl:
Question "What Champion plugs are you running"?
NGK
Am I doing something wrong?? :realcrazy: I've run Champions in my mopars for 40 years, zero issues. My 360 in my Ram had 326,*** miles, ran fine with Champions on 100k mile changes. Now that I think of it, I haven't changed spark plug in our '80 Dodge 5.9 in 5 years. Nor in my Duster in 5 years. Nor my '89 van 360 in 5 years. All run perfect. Please help me understand..... Did I miss the memo ??:realcrazy:
Me too. I have ran Champions in every Mopar I have owned since 69. Never an issue or misfire.
My comment was a reflection of some opinions that have nothing to do with the question. Happens quite a bit. :)
