The question is how long the electrode functions before before it loses efficiency. There's a reason that new vehicles go 100,000 miles between plug changes, but I guess if you don't drive your car much (if at all) it doesn't make a difference..
Right. If you are a cheap skate that makes sense.
They are a ***** to fire, and copper to rare earth they don’t read the same.
If you need to go 100k on your plugs you are in the wrong hobby.
Ask the Autolite guys what a ***** it is to fire those clunkers.the center wire is harder than the NGK and the Champion. The Champion is the softest. They were designed that way for a reason. To make them easy to light.
Much less load on the ignition system and far less misfires compared to NGK and Autolite.
If you can’t spark mark the center wire the plug is too hard, the ignition is junk or both.
