What Champion Plug ru Using in you 340?
By the way out here in the Phoenix AZ area both Orelileys and Autozone are out or limited stock on all the non racing Champions we discussed here.
And I have the walnut shells as well lol
NGK Copper plugs were in use in the mid 70s. I had them in my Honda m/cycle. The Champion R-6 plugs did not have copper & fouled very quickly. I remember adverts by Champion rubbishing the NGK copper plugs, saying the copper would melt, yada, yada
Now Champion &...........the others use copper.
The copper centre electrode has NOTHING to do with electrode tip material, which could be steel, Plat, Irid, Yttrium, etc.
The copper is NEVER exposed to the flame; it is enclosed in a nickel steel jacket. What the copper did was to extend the heat range of the plug. It removed heat faster so that a hotter plug can be used to burn off deposits, but not cause pre-ign at higher loads.
Those who really want to learn [ & not the BS in this thread ] about spark plugs, heat range, spark gap etc should buy the Bosch Automotive Handbook. I have the 9th edition, 1544 pages. There is 8 pages of fine print on ign systems.
