joshua dewitt
hey guys, built 318 in 73 swinger, @3000 lbs +/-.... 28" tires, 3:50 gears... a904, tf2 shift kit, billet servo and piston 5 clutch forwards... vent relocated... mp 340cam, high rise carb, 600 cfm holley 4100 , flat 4 ignition system. raised compression (0) zero decked.
looking into a good decent convert for street/ performance use... looking into the 2200-2500 rpm stall range... but want good street manners ( no major slipping/overheating) and run hard when punched... lennys, great info can't afford, don at performance converter spoke once and didn't return calls? , and a little to high on prices... looking to spend up to 500.00 cheaper the better, not don't want major junk either. have anyone ran hughes 27-25hd 2500? boss hoss street bandit 2200-2500? performance automatic #pa12201 11" ? I did talk to someone at ptc... and suggested his 9.5: billet 475.00 plus freight, and says 2500-2800 stall, and suggested would work well. anyone used here stuff?
