What doors interchange on a 71 Demon?
a34
The Etowah Flash
Etowah, Tn.
Guys,
What doors interchange on a 71 Demon? I need a passenger side door. I was thinking they are the same on A-bodies from 70-72. I think they made a change in 73 that impacts weather-stripping. Is that right or will more doors fit? Maybe 68-69?
Thanks!
:burnout:
I believe all of the door shells will physically interchange. But there are difference between glass and mounting holes over the years. They also relocated the inside door handle in '73.
70-72 should work OK. think they went to the vent window in 73-76 even though the outside of the door is the same
Direct fit is 1970-1972 Duster and 1971-1972 Demon. You could make any shell from 1967-1972 work with some modifications.
