Duster Drag Car
going to my first test and tune saturday at lebanon valley dragway in n.y. 73 duster fiberglass hood and bumper, lexan front and back, sides are glass, fenderwells gutted, doors gutted ,trunk gutted, sheet metal dash one racing seat,tubed, ss springs relocated inwards with 2 inch spacer blocks,8 3/4 with a spool 4.30 gears fresh,29.5 x11.5 x 15 slicks on there final passes. Beefed up 727 rev manual fresh,rebuilt 9.5 converter only around 2800 -- 3000 stall wanted 3800, sub frame connectors ,dual batteries in trunk, 5 gallon fuel cell, adjustable drag shocks, factory front dics new pads and calipers rear drums new pads. Need wilwood front discs with driied rotors maybe this winter. Power plant is a fresh 68 440 30 over factory forged crank, eagle 4340 h beam rods je pistons flat top 2 valve release , three bolt comp solid lifter cam 587 609 lift with the 1.6 rocker arms, pro comp aluminum heads basic porting and matching coustom lenghth push rods, edelbrock victor intake with a 2 inch spacer, holley 850 power valves pluged 76 jets 37 squiter nozzles. Hooker fenderwell headers, 600 plus hp car should weight under 3000 lbs. Seems to run real strong week points are stall speed, old sicks and the brakes will only hold her back to 3000 rpms before she pushes going to be interesting first day with new combo i only have about a dozen passes under my belt in a couple different cars this should be the fastest to date. Any estimates on my et and mph?
