I would like to change the fluid in my 8-3/4 sure grip as i just got the car and have no idea when it was changed last, neither did the guy i got the car from. It's 3.23 gears and i'm not sure if it's cone or clutch type. Do you need to use different fluid depending if it is a clutch type or cone type? and if not what fluid do you guys use and recommend? how much do you put in?
