Yep, they were originally built for around town commuting, not so much long-distance highway use. Although there were brave souls mixing it up out there.Blast was a single, right?
I believe that's what my wife learned on in one of those schools at the HD dealer.
We won that in a raffle.
The Saurekrautes were a disaster for Mopar. Then Brenda Stronich, Fiasco and now Stellantys. I do not see this in a positive light either. Much after 75 they fell down the outhouse. The early electronic ignition was good. Better than Ford and GM. The lean burn was a good idea buut probably would have benefited with newer electronics developments.Companies are taxed on tooling weather its used or not. Some try to sell it if they can but most scrap it. I seen companies scrap 1/2 million in new tooling because they decided to cancel the project. In a merger, I can totally see it getting scrapped, the only savior would be if someone knew what it was and took it from scrap, but there are issues with that. If they started casting with the tool, then they we're not scrapped per the companies filings, so that is a problem and the guy using the casting without permission has a problem too, as they don't own the tooling. Plus casting tooling isn't set and forget, it has up keep, so if someone had it, it cost to keep it functioning. Then there are storage costs.
He will drop dead by years end. Maybe he could be the family Thanksgiving turkey?I bought a 78 NOS 440 block, with pistons and rods only, in 1984 in a shop a mile from my house. The cost was $250 and I put it in my 71 Cuda. He had a few of them and when I went back for another all gone. Another guy that was instrumental in getting surplus Mopar stuff that Chrysler was getting rid of was Jack's Auto Parts in N.J.. He was also one of the guys that helped bring a Mopar swap meet to Englishtown, only to have it destroyed by the IRS at it's grand opening and that was around 86. Maybe with the 87,000 new IRS workers we'll never be able to go to a swap meet without paying taxes on everything you buy. This president's term can't end soon enough for me.
I'd still like to know the situation with all the B/RB engine "rights" and tooling that was bought from Chrysler in the late 70's/early 80's.
Why would a company buy that stuff and then do nothing with it?
AMEN BROTHER!Sure makes me want less government more and more. They are all dirty. Every. Last. One.
Uhhh, You ain't Seen Lightning Heads, or Cams , have Ya? Or the Thunderbolt? The Sportster Platform has been Kicking Big Twins SQUARE in the NUTS for about 65 years...Buell motors were essentially Sportster motors. Working in the Parts department of a few H-D dealerships I sold and shipped lots of Buell obsolete parts overseas after Eric and Harley parted ways. The Buell Blast was pretty much junk and many were wrecked because they were used in the bike rider training classes. You can't imagine what they looked like after numerous drops.
Missing your pointUhhh, You ain't Seen Lightning Heads, or Cams , have Ya? Or the Thunderbolt? The Sportster Platform has been Kicking Big Twins SQUARE in the NUTS for about 65 years...
Lol, it is common knowledge that a stock Sportster at 65 cubic inches and weighs 385 pounds racing against a 74 cubic inch Big Twin that weighs 500 pounds has a power to weight advantage. Add heads and cams to the Sportster and again common sense. Neither bike back in the day put out more than 55-65 horsepower stock.Uhhh, You ain't Seen Lightning Heads, or Cams , have Ya? Or the Thunderbolt? The Sportster Platform has been Kicking Big Twins SQUARE in the NUTS for about 65 years...
ya know I think that’s a dick move and all parties involved who do that **** need to be ***** slapped.
The Old ones come with heads, Hemispheric Ones, unless Ya build a Basket Case! Then Ya gotta find Yer own!Lol, it is common knowledge that a stock Sportster at 65 cubic inches and weighs 385 pounds racing against a 74 cubic inch Big Twin that weighs 500 pounds has a power to weight advantage. Add heads and cams to the Sportster and again common sense. Neither bike back in the day put out more than 55-65 horsepower stock.
Hell, even in the 80's thru the mid 2000's most stock Big Twin barely made 75 hp and that was with pipes, jet kit, and hi-flow a/c.
I picked up and Transported the one lung from Naples FL, after Hurricane Wilma. Threw that Lil Thang around like a cheap hookerYep, they were originally built for around town commuting, not so much long-distance highway use. Although there were brave souls mixing it up out there.
The Blast! was designed to be wrecked and I had dozens pass across my lift that fixed after being dropped repeatedly that looked show-room new with minimal effort and less than $100 in parts. At that time, turn signals were $5 (and flexible so they didn't break), brake and clutch levers were $10, and the shifter and brake pedal were $15 but the shifter was on a spindle so it rarely broke. The plastic was color-molded. Sander and a buffer and it was good as new. The head lamp mounts were the worst, it was impossible to straighten completely. Even replacing handlebars and grips was under $100.
It was designed so that 'contact points' were cheap and easy to replace. I had one that got endo'd at high speed that I fixed for well under $500, and it had the tail tucked up between the frame and tire, and had landed squarely on the instrument cluster. That was the Dumpster Baby (long story) Blast! and I ended up making two grand on that bike.
Lucky duck, I had to buy all 4 of mine.
I disagree. It was a fine highway bike and would run interstate speeds double with little stress. Performance king, no, but I put 1000 miles on one in one night, back around 2002.
HD was never about horsepower. They did, however make fantastic torque.
