greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,748
- Reaction score
- 1,477
On the high end builds some of the guys use pistons with ceramic coatings on the piston tops (correct terminology?)
David Vizard thinks the coatings would be very beneficial on aluminum heads in one of his many how to-horse-power-engine books. -I can't remember him illustrating any results in this particular category.
I bet that coating the exhaust runners would help some, but once all of the metal gets to operating temperature, wouldn't it negate any insulating benefits? -Except for cooloff periods in drag racing maybe?
So they coat the tops of the piston, but I have never heard-of or scene anybody coat the combustion chamber. If the goal is to utilize/maximize the combustion energy as much as possible (instead of bleeding/leaking off heat), then I can't imagine coating one with out the other if you were to go to that length.
On the other hand, if the insulation actually, effectively, separated/INSULATED the combustion heat from an aluminum cylinder head, then wouldn't that negate the plus one compression point that people say are the benefits of setting up an engine with aluminum heads.
thanks in advance
all experience, literature, etc. greatly appreciated.
thanks in advance
