what is correct radiator?
gotdust57@yahoo
could someone tell me the correct radiator for 73 duster, it was original 6 cyl ac, now 360 non ac, someone changed radiator and just rigged one in it, maybe the correct part number and was it supposed to have a shroud? thanks
part# 3673905 1973 22'inch 225 AUTO A/C
fan shroud? if i had to guess yes. if not take a 22' 318 auto radiator and use the mounting brackets and shroud from it. the 318 car will have a shroud. this is of course if you are trying to put it back to a slant , or if you just need a shroud for the one you have now....
just trying to get rid of this rigged up radiator and hoping a shroud will help keep it cool in the summer heat. thanks
