What is supposed to be here
I Dont know slant castings but if that is open to the port it would be a very big vacuum leak.
when you cover it up does the vacuum leak go away?
Classic test for finding a vacuum leak is to spray a little starter fluid with the engine running, if you get near the leak the engine will race a little as it sucks in the ether.
You should probably be posting this in the slant six forum -- more likely to find an answer.
