What is this and what does it do?
Electrical and Ignition
  1. Cope
    Cope Fusing with fire
    2,445
    1838
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    3:31 AM
    I'm rewiring my car (71 dart) and removing all the extra B.S..
    It's almost never driven at night but I want headlights. This box has 2 fuses in it for headlights. I thought the headlight switch had a breaker built in, so what dose this box Do?
    Thanks again!
  2. Big_John
    Big_John In my defense, I was left unsupervised.
    260
    223
    Nov 16, 2014
    Syracuse, NY
    Local Time:
    4:31 AM
    That is an Echlin (NAPA) headlight relay.
    • Agree Agree x 1
    • Demonic
      Demonic Well-Known Member
      347
      154
      Mar 21, 2015
      Maryland
      Local Time:
      4:31 AM
      Straight screw cover, no markings = not a Chrysler part. Someone added that. No idea, you'll have to trace the wires.
    • Big_John
      260
      223
      Nov 16, 2014
      Syracuse, NY
      Local Time:
      4:31 AM
    • Cope
      2,445
      1838
      Oct 20, 2009
      San Jose, Ca.
      Local Time:
      3:31 AM
      So can I just Chuck it in the bin or do I need it?
    • Dave NEO
      Dave NEO Well-Known Member
      812
      150
      Jan 6, 2017
      midwest
      Local Time:
      2:31 AM
      try it with and w/o fuses and see what it does -are your headlights working now or not?
    • Big_John
      260
      223
      Nov 16, 2014
      Syracuse, NY
      Local Time:
      4:31 AM
      Depends...
      Yea, you could "chuck it" and use the headlight switch as it was originally built.
      The other option is to wire everything with the relay in place. It looks like you have some wiring "issues" anyway. The relay is a good piece to have as it takes the load off the old headlight switch and will help you have brighter headlights. You could also replace that relay with two Tyco relays, but if that one works, I don't see why you couldn't clean it up and use it.
      Your choice.....
      • Agree Agree x 2
      • 67Dart273
        67Dart273 Well-Known Member
        38,642
        6247
        Oct 14, 2010
        Idaho
        Local Time:
        1:31 AM
        Using headlight relays on these girls is a great idea, but I just would not use THAT one. Looks like it's pretty bad shape. Remove the cover and look inside. Crackedback on here sells a little kit for relays.
        • Agree Agree x 2
        • Cope
          2,445
          1838
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          3:31 AM
          Ok I will save it and move it to the passenger kick panel where my new fuse block is.
          Yes the headlights did work before I removed the bulk head connector.
          This is a race car so all the "extra" wire, old wire and B.S. is getting pulled out.
          Thanks again!
        • Cope
          2,445
          1838
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          3:31 AM
          On second thought can I just but 2 new relays from kragen? Smaller is better for me and this uses old glass fuses that are getting harder and harder to find.
          What part number is the Tyco relay?
          Thanks again for all the time and advice.
        • MrJLR
          MrJLR Built, not bought FABO Gold Member
          4,145
          2792
          May 14, 2015
          Chino, California
          Local Time:
          1:31 AM
          If you'e over 20 years old, you'll be able to get the glass fuses to rest of your life. ...they're not going away anytime soon. ....
          Jeff
        • Dave NEO
          812
          150
          Jan 6, 2017
          midwest
          Local Time:
          2:31 AM
          Did they put a minimum age requirement on the glass fuses? Never saw that coming! ..well whatever it takes to maintain supply for 68 year olds is good thing. I love those little suckers..'specially when you're pry 'em out and they bust in the middle and shoot glass at your eyeballs..
          • Agree Agree x 1
          • Big_John
            260
            223
            Nov 16, 2014
            Syracuse, NY
            Local Time:
            4:31 AM
            IMHO, the relay you have is very simple to mount and wire. It takes care of both high and low beams too.
            The Tyco relays are nice, but I'm sure the next question is "how do I hook them up", followed by "should I buy this expensive wiring kit?". A goggle search will find a bunch of ways to wire them and I think the wiring kits, as nice as they may be, are expensive provided you can do the work yourself. But... you really can't beat the simplicity of the relay you have. Again, that's my opinion.
            FWIW, I buy these: https://smile.amazon.com/gp/product/B000P61E36/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
            and then wire them using a socket like these: https://smile.amazon.com/Bosch-TYCO...=1515340714&sr=1-1&keywords=tyco+relay+socket although I can usually find the sockets cheaper on eBay.
            I always post this for someone that is working with a wiring harness. A piece of plywood and some finishing nails makes things easy... and it's the way they build wiring harnesses in many industries. Lay it all out and replace one wire at a time and then wrap it with non-adhesive tape.
            • Like Like x 2
