What Is This Called?
cpthowdy1369
SAN ANTONIO, TX
hey guys, when you are pulling out dents, instead of drilling a hole into the sheet metal and using a pull hammer to get the dent out, there is a "spot welding gun" that attaches a "pin" to the dent and then you use a slide hammer to attach to the pin and pull the dent out. what is this "spot welding gun" called? thanks guys
