What IS THIS STUFF?
olddman
Cypress, Texas
Have posted several times with questions about the timing chain cover change out on my 1965 273 engine. Now I need some more HELP!!
The intake manifold is an aluminum Mopar. I pulled the thermostat housing off and saw what looked like a build up of scale that was coated inside of the manifold. The stuff is off-white soft and I can scrape it off with my finger nail when wet. When I pulled the radiator hose off the thermostat housing the neck of the housing had this build up on it also. Had to use a wire brush and scraper to get it off because it had dried. From what I can see there is none in the block.
I have thought about removing the intake and trying to clean it out by soaking it in a bucket of vinegar or radiator cleaner.
Does anyone know what this is, ideas on cleaning it out and how to prevent this from happening again?
Are you using distilled water? It could be lime or calcium deposits from regular hard water. It could also be electrolysis as mentioned above, from dis-similar metals mating against one another. It happened to the Statue of Liberty, it can happen to us!
Someone might have used tap water in the past to fill the cooling system. It supposedly can cause hard water deposits, and calcium can form if the antifreeze/water ratio is off and tap water is used. Ive never personally noticed any issues topping off with the hose every now and then
The easy purchase is a 50/50 premixed antifreeze like from Prestone.
Thanks to everyone for their suggestions. I knew that I could count on help from members.
Hope that I can help in some way in the future.
I have seen a LOT worse than that......
Corrosion so bad that part of the gasket sealing area was eaten away.
Don't worry about it. Use pre-mixed coolant, it will have the correct water in it.
