What pulleys for manual steering 1970 duster v8
Small Block Mopar Engine
  1. StimsonGarage
    StimsonGarage Well-Known Member
    180
    22
    Jul 8, 2013
    United States
    Local Time:
    11:40 PM
    926C9BC4-C8F6-4799-8A82-44FE5841A212.png hey guys so I recently installed a cvf vbelt water pump pulley and crank pulley and alternator bracket on my 70 duster. My issue is the crank pulley is too small and causing my voltage to be low at idle. What’s the correct crank and water pump pulley combo I need. It’s manual steering too. Part number and website would be awsome thank you. Here’s a pic of my engine
  2. 4spdragtop
    4spdragtop Well-Known Member
    28,312
    8131
    Aug 28, 2009
    Wasting time here
    Local Time:
    10:40 PM
    Google bouchillon performance. I've heard and seen lots of recommendations for them.
    • Thanks! Thanks! x 1
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      2,343
      1822
      Jan 1, 2018
      Southwest VA
      Local Time:
      11:40 PM
      I'm wanting to say the factory steel one is 6-1/2 to 7 inches, and it uses the same size on the water pump. Correction, 6-1/2 inches. Larger ones are usually multiple belt a/c pulleys.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      13,992
      3422
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      10:40 PM
      The smaller crank pulley can also lead to overheating. Kim
      • Agree Agree x 2
      • oldkimmer
        13,992
        3422
        Nov 11, 2006
        Local Time:
        10:40 PM
        How big is the w/p pulley? Kim
      • abodyjoe
        abodyjoe Well-Known Member
        20,339
        5250
        May 22, 2004
        Berlin,N.J. 08009
        Local Time:
        11:40 PM
        • Like Like x 2
        • Thanks! Thanks! x 2
        • abodyjoe
          20,339
          5250
          May 22, 2004
          Berlin,N.J. 08009
          Local Time:
          11:40 PM
          don't forget the proper alt. bracket too.
          • Like Like x 1
          • abodyjoe
            20,339
            5250
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            11:40 PM
            for manual steering
            • Like Like x 1
            • Donnie514
              Donnie514 FABO Gold Member FABO Gold Member
              228
              100
              Mar 23, 2019
              Hartville, Ohio
              Local Time:
              11:40 PM
              How long do you let it idle? If it does not over heat there should not really be a problem.
              If the voltage goes below 12.6 ah maybe 12.2 at idle it may be a weak battery unless you have some accessories on.
              It looks nice, you spent the bucks, so if it is not broke don't fix it.
            • StimsonGarage
              180
              22
              Jul 8, 2013
              United States
              Local Time:
              11:40 PM
              I put my old crank pulley on thats about 6inches wide. Had the belt just run the alternator and crank and voltage stayed steady at 14. So it’s definitely pulleys. I’m gonna order the ones the other guys suggested
            • StimsonGarage
              180
              22
              Jul 8, 2013
              United States
              Local Time:
              11:40 PM
              Thank you everyone big help. Mopar to ya
