what pump and pulleys do i need
71scamp78
terre haute indiana
I'm putting a 66 383 in my 71 dart and wondering what power steering pump and bracket i need I don't think I can my brackebracket off my pump and use it's off my dart. I don't think my crank pulley will work either. What all do I need for crank , water pump and what power steering pump and bracket will work on the 66 block.
You need all matching pulleys and brackets from a big block. Non a/c stuff is getting harder and expensive to find.
Does it matter what yr big block. Found a 77 440 with everything it's a ac car . Will ut work on a 66 383 block. Only thing is I got to buy the whole engine and trans but only cost 250.
Depends if you are run I g a/c or not. Ac pulleys and brackets and pulleys need to be used with an a/c compressor.
I am pretty sure the yea doesn't matter.
