What rad in my 66 wagon?
Rockerdude
Rock n' Roll and A-bodies
Arizona
I'm putting a 318 in my wagon and was wondering what to do about a radiator. I could find a 273 easy and water pump, but what about later a- body stuff? Does it fit? Thanks.
I have a 1965 Valiant wagon with a 318 and needed a radiator. I purchased a aluminum one from eagle off e-bay for $200. and it was twisted. Had another one sent from them and same problem. Gave up on the e-bay radiators and had a aluminum one made locally for $340. It's a two row with 1" cores that they make here in Michigan. He uses Delphi cores so they are very nice. He doesn't drill any holes in the brackets so you can mount it where you want. I centered mine where I wanted it and drilled holes to use the original mounting holes. Mine was pretty close to the hood with the Valiant hood but you might have more clearance with the 66 Dart hood. I don't have a fan shroud and it runs right in the middle of the factory gage sitting in traffic. Very please with it. Jayson
http://www.wwwsuperiorradiator.com/
