What shoud it run? Estimated HP anTQ?
KnuckleDuster
Texas
Duster
3225lbs with a full tank.
410 ci 360
10.1 scr
Stock 60779 Edebrocks 63cc
Hedman 1-5/8" headers and 2.5" exhaust
Proform 750 cfm carb on an Edelbrock Air Gap
TCI Streetfighter 727
3.23 Suregrip
275/60R15 (28"x10")
Factory pinion snubber
Espo 1" over springs
Factory front sway bar
Stock 340 torsion bars
Monroe Matic shocks front and rear
Welded MP frame connectors.
Finally getting the car sorted, but looking for ideas on what to expect and improvements on the combination.
Mainly a street cruiser but would love to hear tips to get it to turn respectable times at the track. I might swap in a 3.90 spool for racing. Fun car as is, just looking to learn.
Thanks! That's about what I woild expect, too.
Would like to find out the path to about 11.60. (no cage) and I would be done.
12.9-13.2 with 3,9 s
I ran low 13's with 3.23, mild 360 (.455 lift/268/276 adv. dur. and cast heads) with same tires, and weight of car. He'll do much better. Even with 3.23's, I guess 12.30's at 106 mph. He might have too much cam for the gear....
not sure on that ,anyway time will tell what is weight with driver ? converter may go 3000 comp a little low with the alloys .when are you doing a pass in it ? knuckle
Hopefully this weekend. Have only run it once and it was breaking up at about 4000rpm in 2nd, but it cleared up in 3rd and ran a best of 14.4 at @101mph.
Judging by the time I lost, I am hoping for mid 12's now that the issue is resolved. Sounds like that shouldn't be too far off going by the estimates you guys are giving. Will post results when I get them. Thanks!
