taco502001
- Joined
- Nov 9, 2005
- Messages
- 73
- Reaction score
- 2
I have asked this question before and was set on 9.5" 4k stall and 4:10 gears and dyno tune. But I had lost my job and had to use some of my savings to take care of bills, anyways I have a new job now. Theoretically as long as I do not get fired or they do not try and cut my hours I make 2.50 an hr more than what i was making and now have mon-fri 10-6 weekends off.
this is all theoretical but I made a budget and if I do things right I will have 8k in savings by Dec 08 and thats getting rid of all my debt but the car loan which i would owe probably 4k or less on at that time.
Hears the thing I want to know what can I have done to my car for 8k, I have been looking at kit from thesuperchargerstore.com, or going with indy 440-ez 1 heads or better, a custom ground scott brown solid roller cam, and the ptc 4k stall and 4:10 gears
I have also been contimplating a 500 stroker backed up with indy heads and etc...
what I want is an 11 second street car the car will be driven on street mostly but if I take it to the track 1-3 times a year I want to be able to run 11's . I have always wanted a low 11 second 10 second car which is all and well but its not for driving around on the street and to car shows 45 miles away
Anyways here is the setup as of now
Weld Chrome Wheels with 4 1/2 bolt circle with 28x10.5 mickey et streets
Mighty Demon 850 Carb
Wieand G Force Aluminum Intake
K&N Air Filter with extreme top
Mallory Electronic Distributor 8mm copper wires
Drive Shaft loop
Frame Ties
TCI Line Lock with Chrome B&M shifter button
Milodon Deep Oil Pan
Hooker Super Fender Wall Headers
8 3/4 Rearend with Moser axels
B&M 3000 Stall Converter
Forged Steel Crank and Rods
Front Disc Brakes
Flow Master Mufflers
3 1/2" exhaust to Chrome tips
9.7 to 1 compression
292/502 Comp Cam and kit
Aluminum Water pump and hosing
Braided steel fuel lines with connections
March Pulleys
906 Heads with harden seats
3-angle valve job with bronze guides
Perfect circle seals
Comp cams double spring retainers and keepers (valve locks)
Completely balanced bottom end
Special 5/16" T-6061 Pro Engine Mounts (Elephant Ears)
3-core radiator
Hayden Super Heavy Duty Trans cover Large U-joint drive Shaft
Super Stock springs 1.140
NASCAR Torsion bars
Drive Shaft loop
Frame Ties
Front Disc Brakes
March Pulleys
3-core radiator
NASCAR Torsion bars
