diymirage
HP@idle > hondaHP@redline
so, i bought this engine and tranny to put in my 71 duster (/6-904)
ill post a few pics, and then get my thoughts straight (ill try not to ramble)
so, it is a 75 360 out of a motor home
(apart from a good cleaning) the tranny should be all set
i should hook up a tranny cooler (not sure if my 904 has one, and if it does, could i use its lines?)
the thing i thought was a sensor is the neutral switch/back up light doohichky, again, use it or does the one from the 904 work?
on to the motor, i think the best way to determine the state of the engine is to get it on a stand and check the compression on each cylinder, if they are all good i will leave the heads on and the pistons in place
the oil pan is a truck unit with a rear sump so it and the pickup need to be replaced
i should check/replace the timing chain/gear and water pump
valve springs, can i assume the springs are good if the compression it?
i almost feel like if i go through the effort of replacing the springs i might as well put a new cam in there while im at it.
the carb will also need a good cleaning, maybe just replace it while im at it?
same goes for the intake
ignition, someone suggested the distributor might be geared more towards hauling stuff and should be recurved
oh, accessories, the /6 has powersteering, AC and a alternator
i would prefer to use the /6 parts since they are hooked up, will they bolt up to the 360 mounts?
the accesories on the 360 looks quite different and seem to be oriented different aswell
(maybe the alternator on the 360 is a higher output unit and would be worth considering?)
any other thoughts?
any other thoughts?
