74fldart
hi fellas, im putting the backing plates on my rear end and since i dont have the factory bolts i was wondering what size do you guys use. this is for a 8/3/4 / dana set up. i tried to get a 3/8 bolt in the holes but the axle tube is so close to the hole in the bearing housing that the head of the bolt wont allow it to go in right, i guess the factory ones were ground down on the one side or flattened off. anyway i tried a 5/16 and it will work but the holes look like there made for a 3/8. moser sells a set but its like $ 30 .00 . any body have any suggesations?
