What size front runners are the hemi shoot out ss cars using.
I’m not sure about the Hoosier 28”, they may clear because they are more rounded, but my 28” MT SR radials were catching, they have a more square edge too though.
In my case I had to make a gradual pie cut on the front edge. At the bottom I cut an approx. 5/8” pie that went up about 6.5”. (5/8” removed at the bottom that tapered to nothing at the top of the cut). No problem with clearance now but it was touching before. Hope this helps.
Yes sir, that helps & it definitely looks great.
They will fit but make sure your alignment is done and get the max. amount of caster. They will clear the front edge. ps it works much better if you get the longer aftermarket upper control arms it will fix a lot of the bump steer.
as for the bump steer! One day I get a package in the Mail and it's from Chrysler with new non breakable intake bolts and a pair of front spindles with relocated steering arms to correct the bump steer picked up a couple MPH after the change
