What size OE fan???
mopowers
West Sacramento, CA
What size fan (diameter) came stock on a 67 small block Dart with shroud? Did it have a clutch, or was it direct drive?
Thanks!
I think mine has a 17" 6 or 7 blade with no clutch but it has dealer installed air and no shroud.
Thank you! I think you're right on the 17" because my 67 shroud is only 19" round, so anything more than a 17" fan would get awfully tight. Thanks again.
specially since the flex fans expand quite a bit as you get on it
